I CANT GET PLUG INS TO AUDACITY! HELP ME
collins23
Post by collins23 » Thu Jul 21, 2011 1:59 am
i have windows internet explorer and i cant find the plugins folder for audacity maybe somebody could give me the url so i can go right to it but i cant put anythng in it because i cant find it. i dont want the url to the sourceforge plugin download site i want the plug in to go directly into the folder and paste the plugin in there.
Re: I CANT GET PLUG INS TO AUDACITY! HELP ME
Post by Gale Andrews » Thu Jul 21, 2011 2:15 am
collins23 wrote:i have windows internet explorer and i cant find the plugins folder for audacity maybe somebody could give me the url so i can go right to it but i cant put anythng in it because i cant find it. i dont want the url to the sourceforge plugin download site i want the plug in to go directly into the folder and paste the plugin in there.
Please do not write in UPPER CASE or your posts may be rejected for shouting. I converted your post to lower case.
A URL is only for an address on a web site, not for a path in a computer file system. To install new plug-ins, place them in the "Plug-Ins" folder inside the Audacity installation folder. On Windows computers, the Audacity installation folder is usually under "Program Files". If you did not change the folder you installed Audacity Beta into, it's usually C:Program FilesAudacity 1.3 Beta (Unicode) on 32-bit Windows.
It's C:Program Files (x86)Audacity 1.3 Beta (Unicode) on 64-bit Windows.
Please restart Audacity after adding the new plug-ins.
If these are VST plug-ins, please read this page:
http://wiki.audacityteam.org/wiki/VST_Plug-ins
If you need more help please say exactly which plug-ins you are trying to install.
bobillwho100
Post by bobillwho100 » Mon Jan 09, 2012 8:36 pm
Hi there. I am having a similar problem. I have Windows 7 and installed Audacity. I can't find how to install the plugins though. Can anyone help? Thanks. :)
Post by Gale Andrews » Mon Jan 09, 2012 11:14 pm
bobillwho100 wrote:Hi there. I am having a similar problem. I have Windows 7 and installed Audacity. I can't find how to install the plugins though. Can anyone help?
Please read the post above the one you wrote and see:
http://audacityteam.org/download/plugins
