export/import
export/import
I exported recording as .WAV file and next I can't import this file. The program doesn't see any .WAV file. What is wrong?
Re: export/import
Nowhere near enough information for us to help you!
What file name did you save as? Was there any metadata?
In which directory did you save? What OS; what exact version of Audacity (menu Help > About Audacity...)?
Are you using menu File > Import > Audio... or menu File > Open...?
Have you used the OS's Search function to try to locate the missing file?
Re: export/import
OK,
xxx.wav; metadata only artist name
c:audio; XP Prof.; 1.3.13
both
I can see the file in My computer window.
both
Re: export/import
Does the file play in other programs?
What size is the file?
Re: export/import
Yes, for example in Windows Media Player
2 308 276
As I mentioned I cannot see any other .WAV file in audacity.
2 308 276
Re: export/import
bits? bytes?jozef wrote:What size is the file?
2 308 276
File menu > Import > Audio
Do you have the file filter (button) set to "All files"?
Re: export/import
Does the file name or artist name contain any characters other than a-z, A-Z, 0-9? Are you using any non-English characters?
Re: export/import
2 308 276 bytes
Yes, Also in Preferences I tested to check in "Filters chosen in OpenFile ..." next I checked out "Filters ..." and inserted rule WAV. I also tried .WAV, *.WAV and no success
no non-English characters
I think most important remark is that I don't see any .WAV any .MP3 file. It's a pity.
2 308 276 bytes
