Shorten wav file
blockie
Shorten wav file
Post by blockie » Sat Jul 02, 2011 12:06 am
I have a av file,Cuckoo, that is 10 cuckoos in length. I would like to shorten it ti 2 cuckoos. How?
Re: Shorten wav file
Post by kozikowski » Sat Jul 02, 2011 12:30 am
You can either select the first two cuckoos by dragging and Export Selection, or select everything else and delete. Then do a regular export.
Audacity will not save a sound file. You have to export one.
blockie
Post by blockie » Mon Jul 04, 2011 2:11 am
Solved. Thanks.
