System has worked fine in the past. It is a Win7 Pro 32bit. I had recently loaded two other Spectrum Analysis applications, I removed them, and clean installed Audacity b1.3.13 (the problem was first noticed with b1.3.12) thinking they used a common component. It made no change. The same three programs are running on a 64bit W7 system with no issues.
It appears the FA window is being called from within the executable, and not as a plug in. I have reviewed all the Preferences and cannot see anything that might cause this.
Anybody got any ideas on how to proceed with the troubleshooting ?
