Hi Guys,
Is it possible to change Bit Rate, Audio Sample size and Audio Format (CCITT A-Law) of a .wav file with this application? I cant find this in the tutorial.
Thanks.
Re: Bit Rate, Audio Sample size and Audio Format (CCITT A-La
Last time I had to do this...
Depth/Rate Conversion
-- Change Project Rate (Hz) lower left > 44100
-- Track Name > Set Sample Format > 16-bit PCM
-- File > Export > Format > Other uncompressed File Types (or whatever you want)
Thanks Koz, I did try that, unfortunately it doesnt have CCITT A-Law format :...( only has PCM and Float.kozikowski wrote:Last time I had to do this...
Which version of Audacity are you using? (look in "Help menu > About Audacity" - the full version name will be something like: "Audacity ® 1.3.14-alpha-Jun 14 2011 (Unicode)")tankboyz wrote:unfortunately it doesnt have CCITT A-Law format
