*Audacity won't let me select sections of audio wavelength!
npags711
Post by npags711 » Thu Jun 23, 2011 10:47 pm
Hey, if you could offer any help on this as soon as possible - I'd be extremely grateful...it's time sensitive
I have a 3 hour audio edit I'm currently working on - with multiple tracks...
After rendering a noise removal to the first and second track...the noise removal was successful but now Audacity won't let me select sections of the audio.
It seems like there's a pattern where it won't let me select the audio - every .25 seconds or so maybe. In other words, it just won't allow me to place the cursor at certain locations/intervals and select whatever portion I want to select....
I thought it was just a temp glitch so I closed out of Audacity and opened back up - but same problem. I exported the audio and re-imported back into a new project and same problem.
I re-rendered the audio with RealPlayer and also with Adobe Premier Pro - but same issues. I opened up the same export in Adobe SoundBooth and the problem is gone so it's def. an issue with Audacity...but that wasn't much of a surprise.
I haven't worked with SoundBooth before...that's why I want to fix the current problem with Audacity.
I need to figure this out immediately - it's extremely urgent...
If there aren't any solutions....I think I'll have to re-record the audio...and render...then import back in....
Thanks - I appreciate any help or suggestions you can give ;)
Re: *Audacity won't let me select sections of audio waveleng
Post by kozikowski » Thu Jun 23, 2011 11:05 pm
Make sure Snap To is not selected in the lower part of the edit window.
npags711
Post by npags711 » Fri Jun 24, 2011 12:00 am
Koz - thank you so much...I forgot I clicked this after I rendered the noise removal...and I never did so before.
It did the trick - thank you very, very much!!
YOU'RE THE MAN! :D
