Stereo Phone out. 1/4 to 1/8 cable.steve wrote:To record the keyboard, you need to plug an audio output on the keyboard to a "line input" on the computer. Look on the back of the computer and there may be a line input there. The headphone socket is for playing music, not recording music. If there are color coded sound card sockets on the back of the computer, you need to plug the keyboard into the light blue one.
Which connection are you using on the keyboard?
No device found on keyboard?
monsterbasher
Re: No device found on keyboard?
monsterbasher
Nevermind thanks for your help Stevie I found it worked after I plugged it in the blue in.
