Hi i was wondering if i could send an audacity file thru SKYPE?
There are two folders "audacity.aup" and "audacity data" i think. It has codes like e000301a or sth.
So i was wondering if my recipient would receive my audacity file and would she be able to open the file if she can receive it?
Thanks in advance.
CAN YOU SEND AN AUDACITY FILE THROUGH SKYPE?
- Quality Assurance
Re: CAN YOU SEND AN AUDACITY FILE THROUGH SKYPE?
See:
https://support.skype.com/en-us/faq/FA3 ... sing-Skype
You have to use 7Zip or the built-in Windows compression utility to add the .aup file and _data folder to a zip file, then send the zip. Please ask Skype if you have questions.
If you imported files into your project you must copy that data into the project before saving and sending it. See:
http://wiki.audacityteam.org/wiki/Sendi ... _to_others
