select tool does not select
Richard McDonald
Post by Richard McDonald » Fri Jun 03, 2011 11:21 pm
my select tool worked the first time I used Audacity, but has not worked since. I use Audacity for story audio, not music. When I want to select a dead section to delete the select tool does not work.
Re: select tool does not select
Post by Gale Andrews » Fri Jun 03, 2011 11:51 pm
Richard McDonald wrote:my select tool worked the first time I used Audacity, but has not worked since. I use Audacity for story audio, not music. When I want to select a dead section to delete the select tool does not work.
Are you deleting short selections less than a second? If so make sure you have not got "Snap To" checked in Selection Toolbar at the bottom.
If that is not the issue, please give more details on how selections are not working.
Richard McDonald
Post by Richard McDonald » Sat Jun 04, 2011 2:27 am
Thank you Gail, the 'snap to' box was the problem.
Richard
