Generate and Effect menus missing/incomplete
On a fresh install of Audacity 1.3.13 on Windows XP, the "generate" menu is completely missing, and the "effects" menu only has the options "fade in," "fade out," "leveler," "noise removal," "normalize," and "truncate silence."
- Quality Assurance
Re: Generate and Effect menus missing/incomplete
It's not a "fresh install" because you modified the Audacity Preferences at some stage.skwerel wrote:On a fresh install of Audacity 1.3.13 on Windows XP, the "generate" menu is completely missing, and the "effects" menu only has the options "fade in," "fade out," "leveler," "noise removal," "normalize," and "truncate silence."
You can fix your issue by clicking Edit > Preferences: Interface, unchecking CleanSpeech mode and click OK.
