It means, File > Close before you place the .aup and _data folder in a zip file. That way, Audacity will remove any .au files used purely to facilitate undo and redo while the project is open, so that they won't give an "orphaned files" warning when you re-open the project as they do for us.jrssystemsnet wrote:I'm sorry Gale; I don't have any idea what that means. I followed the steps I posted, exactly as I posted them - if you can explain what you mean by "packaging before closing", maybe I can answer?Gale Andrews wrote:Did you package the project before closing it?
If you can re-open that project you last sent us (audacity_broken_20069) without any errors about orphaned files then all is OK.
Please do, that's why I made all those suggestions.jrssystemsnet wrote:I can try messing around with it some more if you're interested in some help narrowing it down further
Thanks
