combined files, can't play buzz buzz buzz
TheCatCoach
Post by TheCatCoach » Sun May 29, 2011 1:42 am
Thank you before hand for answering my question.
I combined 2 files together, by importing them into audacity. They only would import as raw data, though their file extensions are .aup. After importing them in, I cut and pasted them, as outlined in the tutorial, together. I then select the play button to listen to the result, I hear a short buzz sound. It's as if everything is compressed. What am I doing wrong?
Thank you!
Marilyn
billw58
Re: combined files, can't play buzz buzz buzz
Post by billw58 » Sun May 29, 2011 2:25 am
AUP files are not sound files. See: http://manual.audacityteam.org/man/Audacity_Projects
-- Bill
TheCatCoach
Post by TheCatCoach » Sun May 29, 2011 2:27 am
Can they be made into sound files?
TheCatCoach
Post by TheCatCoach » Sun May 29, 2011 2:44 am
I just figured out how to save them as .wav files... now it works... thank you!
