I've set labels for an album which I've recorded using Audacity. I export the tracks. But some of the tracks continue for around 4s past the expect end as a result of which they contain the lead-in to the next track.
I can't find any options etc to stop this. I'm exporting to MP3. Any suggestions?
Papadeltasierra
Export Labels doesn't split at the label!
papadeltasierra
Re: Export Labels doesn't split at the label!
Which exact version of Audacity are you using? (Look in "Help menu > About Audacity")
waxcylinder
I'm betting it's 1.3.10 which had this as a known bug ...
papadeltasierra
1.3.10 it is. A cigar for the previous poster
. Off to install the newer beta.
Many thanks,
Papadeltasierra
Many thanks,
Papadeltasierra
