Latency connection is zero
blahtobling
Post by blahtobling » Wed May 25, 2011 3:44 pm
I have searched all the latency questions about the error zero... I have gone into preferences and made sure it was set to 100 and -130.. I made sure the snap to it was not on.. I changed the settings for the over dub.... I am about ready to pull my freaking hair out... please can anyone help??
It doesn't look like this posted so I am re-posting sorry if I duplicate
Re: Latency connection is zero
Post by steve » Wed May 25, 2011 4:55 pm
Both of your posts were sent and were waiting to be approved by a moderator. Sorry about the inconvenience, but this has become a necessary step due to spammers abusing the system.
I've just read your post three times, and I'm still not sure what the actual problem is that you are having.
In case this answers it, the correct method to set up latency correction is here: http://manual.audacityteam.org/man/Latency_Test
Post by Gale Andrews » Wed May 25, 2011 7:19 pm
blahtobling wrote:I have searched all the latency questions about the error zero... I have gone into preferences and made sure it was set to 100 and -130.. I made sure the snap to it was not on.. I changed the settings for the over dub....
Are you are getting the message about all audio hidden behind zero ? If so then you are only recording a few milliseconds and the most likely reason is that you have enabled Sound Activated Recording by mistake and the recording input is below the threshold level at which recording is set to start. The "latency correction" message will appear when you stop the recording.
If this is the issue you can uncheck Sound Activated Recording either in the Recording Preferences (click OK to save the change) or in the Transport Menu.
