Recordings are sped up when played back
Re: Recordings are sped up when played back
Post by Gale Andrews » Mon May 23, 2011 8:07 pm
steve wrote:The problem can usually be fixed by ensuring that the default sample rate in Audacity (Edit menu > Preferences > Devices) and the recording sample rate (Windows Control Panel > Sounds > Recording > Advanced Settings) are the same.
Just to clarify, on Vista and 7 the route would be Windows Control Panel > Hardware and Sound > Sound, and the Default Sample Rate is in the "Quality" Section of Audacity Preferences.
Your best chance (after following the advice to seek a Vista 32-bit driver for the device) would probably be to choose "Windows DirectSound" as "Host" in the Audacity Devices Preferences (as you have done), then in "Sound" (Recording tab, right-click the device > Properties: Advanced tab), make sure both "Exclusive Mode" boxes are checked. Otherwise, you'll be trying to use the rate shown in "Default Format".
