PLEASE HELP!!! PROBLEM WITH EFFECTS
Please help!! I wanted my Audacity file to fade at the end so I did the Fade Out effect and I saved and exported it as an MP3. I just round out that the fade applied to all the tracks so I fades out at random times when your listening. So everywhere it has a new track the think fades out. How can I reverse this effect?
Re: PLEASE HELP!!! PROBLEM WITH EFFECTS
If you still have the Audacity Project open, press Ctrl+Z or select "Undo" from the Edit menu.
If you've already closed the Audacity Project, then unfortunately it cannot be undone.
