changes
tlvky
changes
Post by tlvky » Sat Apr 16, 2011 1:17 am
When I upgraded, it seems that all but a few of the effects had disappeared and the minimum amount of time I can edit is 1 second. Whats up???
Thanks, Terry
Re: changes
Post by steve » Sat Apr 16, 2011 1:32 am
It's a really bad idea to post your e-mail address on a public forum, unless you like spam. I've disguised your address a bit to make it less obvious to spambots.
Look near the bottom of the main Audacity window and de-select "Snap To".
tlvky
Re: changes
Post by tlvky » Sat Apr 16, 2011 1:57 am
Thanks, That took care of the editing problem. What happened to all the effects that use to be on there?
Re: changes
Post by steve » Sat Apr 16, 2011 11:22 am
tlvky wrote:What happened to all the effects that use to be on there?
What effects that used to be where?
Which version of Audacity do you now have?
What operating system are you using?
