Can't open a previously succsessfully stored aup-project. The following window appears:
Header: Fehler beim Öffnen des Projekts
Message: Fehler: not well-formed (invalid token) in Zeile 9
Fleischmann
Code: Select all
<?xml version="1.0" standalone="no" ?>
<!DOCTYPE project PUBLIC "-//audacityproject-1.3.0//DTD//EN" "http://audacityteam.org/xml/audacityproject-1.3.0.dtd" >
<project xmlns="http://audacityteam.org/xml/" projname="00 Caldara Sinfonia 4-3 Cembalo_data" version="1.3.0" audacityversion="1.3.13-beta" sel0="4.4465737462" sel1="4.4465737462" vpos="0" h="0.0000000000" zoom="11.0197205301" rate="96000.0">
<tags>
<tag name="GENRE" value="Drei Violinen und Klavier"/>
<tag name="TITLE" value="Caldara Sinfonia 4-3 Cembalo V1 V2 und Cembalo"/>
<tag name="YEAR" value="2011"/>
<tag name="ARTIST" value="Dieter Fleischmann und MIDI"/>
<tag name="COMMENTS" value="20110413; H2 90°, Dieter Grünke und MIDI"/>
</tags>
Code: Select all
<tag name="COMMENTS" value="20110413; H2 90°, Dieter Grünke und MIDI"/>Code: Select all
<tag name="COMMENTS" value="20110413 H2 90 deg Dieter Grunke und MIDI"/>Are you saying that you have Audacity Projects that do not open in Audacity 1.3.13, but do open in a previous version of Audacity?Fleischmann wrote:I just have to adapt hundreds of my existing files with this handycap yet when I will use v 1.3.13-beta.
