What happened to File Formats under Preferences? Audacity ® 1.3.13-beta (Unicode)
I had the same problem for an 18 minute mono file on my laptop ...when I went to check the Preferences - I couldn't access MP3 Export Setup under Preferences.
MP3 file too big to send
Re: MP3 file too big to send
The File Export options are now in the Export dialogue screen (no longer any need to go digging into the Preferences for them).
File menu > Export
Select the file format type and any other options.
See here for full details: http://manual.audacityteam.org/man/File_Export_Dialog
File menu > Export
To Export in MP3 format you must have "Lame" installed. See here for instructions: http://audacityteam.org/help/faq?s=install&i=lame-mp3RobinEagle wrote:How can I create an MP3 file instead of a WAV on audacity?
To export an MP3, click "File menu" and select "Export". Then choose "MP3" as the Export format (drop-down selection box).
Additional export options (such as the "bit-rate") are accessed by clicking the "Options" button.
See here for more details: http://manual.audacityteam.org/man/MP3_Export_Options
re: Preferences, Thanks Steve - FOUND IT! Works perfectly.
