easier way to edit multiple audio
lukegbk
Post by lukegbk » Thu Apr 07, 2011 8:51 am
so i got this to try and solve a problem im having with my ipod where it plays some tracks at a higher volume than others. i want to know if theres an easy way to import and then export multiple tracks to save time? i have a ton of audio on my computer and it would take forever to import all the seperate files. can someone help me?
waxcylinder
Re: easier way to edit multiple audio
Post by waxcylinder » Thu Apr 07, 2011 11:34 am
The easiest way to do this is to use iTunes to do this. AFAIK iTunes doesn't actually change the soundfiles, instead it just applies varying amplification per song.
In iTunes go to Edit > Preferences > Playback and check on the box that says Soundcheck
You will need to re-synch your iPod for it to take effect on the iPod.
