Just wont record
PHONEMAN
Re: Just wont record
Post by PHONEMAN » Mon Apr 04, 2011 1:56 am
Ok, I went back to where I checked use memory, unchecked it.
Then I noticed another little box right to the right of the 1st box, where I was going to enter the new information, It
was labeled "Choose", I clicked that box, and sure enough one of the options was just like the one you mentioned, I choose that
one , unchecked use memory, saved it, restarted program and presto it works like a champ.
This HP net book only has a 16gb HD, and not alot left at that, and 4 Gb memory.
Thanks for all the help
Phoneman
PHONEMAN
Post by PHONEMAN » Mon Apr 04, 2011 4:32 am
Now its got me thinking........
Instead of using my C drive, which is kinda full.
Could I use my F drive, its a 8 GB sd card. Its empty.
Maybe change it to F, instead of C, keep the info the same except change the C to F drive
Phoneman
waxcylinder
Post by waxcylinder » Mon Apr 04, 2011 8:51 am
I'd be more inlined to move some of the least frequently used (or even redundant) files to the F drive to free up some usable space on the C ddrive for use with Audacity.
Or even dump some of those files onto an external USB disk.
Apart from any other consideration - running with a very full C drive is never a good idea - I always aim for at least 25-33% free space and I defrag the disk regularly too.
PHONEMAN
Post by PHONEMAN » Mon Apr 04, 2011 3:59 pm
Yes, I thought about moving files over to F drive, thats what I will do.
I wonder how much HD space would be needed to record about 1 hour of thunderstorms?
Phoneman
Post by steve » Mon Apr 04, 2011 6:02 pm
1 hour at 44.1 kHz sample rate, 16-bit mono, will require about 320 MB.
1 hour at 44.1 kHz sample rate, 32-bit float mono, will require about 640 MB. (default)
If the recording is stereo it will be double (~1.3 GB).
You will also need additional space for "Undo" files if you edit the recording, and space for exporting the recording. A 1 hour Audacity Project can quickly grow to 10 GB or more if you start editing and/or applying effects.
