recording whatever comes thru the soundcard
donnybrook098
Post by donnybrook098 » Mon Mar 28, 2011 9:17 pm
in windows xp I simply selected auxillary & was able to record anything coming thru the sound card. Now with windows 7 I only have two options between line in & microphone - no auxilary input options. How do I tell audacity to record whatever is coming out of the speakers?
Re: recording whatever comes thru the soundcard
Post by kozikowski » Mon Mar 28, 2011 10:12 pm
It's possible you may not be able to easily record "Stereo Mix" on your new machine. It got harder and harder to do this as the Windows versions advanced. Some new computers make it very difficult.
http://wiki.audacityteam.org/wiki/Recor ... e_computer
If the Usual Suspects fail, you may need to use a money-based solution like Total Recorder.
http://www.highcriteria.com/
Post by steve » Mon Mar 28, 2011 10:14 pm
This is often referred to as recording "Stereo Mix".
Some sound cards call it "Auxiliary" but more commonly it's called "Stereo Mix" or "Mix" or "What U Hear".
Unfortunately the option is not always available in Windows 7 (or Vista).
If it is available, see these links for how to enable the option, or if it's not available, for some possible workarounds:
http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
