How to change songs hz frequency
..I just d/l this program, and wonder how to listen to something in a diff frequency ...I want 432 hz, i tried switching a song to it myself and couldnt hear squat, so Im assuming it must be 43200 is whats meant by 432 hz. ...although to be honest I havent the foggiest notion, wondering if someone can help. thanks.
Re: How to change songs hz frequency
Do you mean that you want to change the pitch of a song?grsp1 wrote:..I just d/l this program, and wonder how to listen to something in a diff frequency ...I want 432 hz, i tried switching a song to it myself and couldnt hear squat, so Im assuming it must be 43200 is whats meant by 432 hz. ...although to be honest I havent the foggiest notion, wondering if someone can help. thanks.
If so you can either use the "Change Speed" effect or the "Change Pitch" effect - both are in the "Effect" menu.
The "Change Speed" effect will change both the pitch and the tempo.
The "Change Pitch" effect will keep the tempo the same, but there will be some sound quality loss due to the "stretching" of the audio.
