Error: not well-formed (invalid token) at line 76
fiveways
Post by fiveways » Sat Mar 26, 2011 3:44 pm
My other post has mysteriously dissapeared but I say again, i keep getting that same message.
The line in question, viewed in Notepad ++ is as follows:
Code: Select all
				<waveblock sta ê                U& ê]) ÿZ$ÿ¼¦—ÿÿÿÿÿÖȼÿÿÿÿÿ¶žÿÿÿÿÿ¤‡lÿ]) ÿU& ê                U& ê]) ÿZ& ÿU ÿ¼¦—ÿÿÿÿÿÿÿÿÿÿÿÿÿ¤‡lÿX" ÿ]) ÿU& ê                U& ê]) ÿ^* ÿO ÿƒY;ÿÿÿÿÿÿÿÿÿ¤‡lÿQ ÿ]) ÿ]) ÿU& ê                U& ê]) ÿR ÿƒY;ÿÿÿÿÿÖȼÿÿÿÿÿÿÿÿÿ¤‡lÿV  ÿ]) ÿU& ê                U& ê]) ÿƒY;ÿÿÿÿÿ¼¦—ÿ®“|ÿÿÿÿÿ¥ˆpÿÿÿÿÿ¤‡lÿ]) ÿU& ê                B ·]) ÿ¼¦—ÿ¼¦—ÿQÿ®“|ÿÿÿÿÿº£’ÿÿÿÿÿªvÿ]) ÿB ·                ( p]) ÿ]) ÿ]) ÿ]) ÿ®“|ÿÿÿÿÿÿÿÿÿªvÿ]) ÿ]) ÿ( p                	 @ °]) ÿ]) ÿ]) ÿ®“|ÿÿÿÿÿªvÿ]) ÿ]) ÿ@ °	                      [email protected] °]) ÿ]) ÿ—sWÿªvÿ]) ÿ]) ÿ@ ° 9                            	 ( pB ·U& êU& êB ·( p	                 Ö111ÿ333ÿ888ÿ===ÿAAAÿDDDÿFFFÿCCCÿ@@@ÿ<<<ÿ777ÿ222ÿ...ÿ'''ÿ   RRRRÿ^^^ÿ^^^ÿ^^^ÿXXXÿoooÿ´´´ÿÜÜÜÿÝÝÝÿ¶¶¶ÿnnnÿXXXÿ^^^ÿ^^^ÿaaaÿýBBBÿIIIÿIIIÿFFFÿ¼¼¼ÿÐÐÐÿÒÓÓÿÏÐÐÿÕÖÖÿèééÿõõõÿÞÞÞÿ888ÿBBBÿIIIÿý000ÿ000ÿ000ÿ“““ÿ“““ÿZYYÿ^IJÿmqÿ’svÿgRUÿqpqÿÔÔÔÿáááÿ+++ÿ000ÿý+++ÿÿ___ÿ]^^ÿ9.-ÿmOKÿ|^[ÿ†ecÿ…isÿqvÿ‘prÿF=?ÿ¯¯¯ÿ®®®ÿÿý)))ÿ(((ÿAAAÿ531ÿ?"ÿJ*!ÿO/'ÿU5,ÿZ<hÿaMmÿaMdÿlMKÿJHHÿ†††ÿ(((ÿý***ÿ???ÿ99:ÿ1ÿF'ÿE&ÿC#ÿL%+ÿ8bÿt8dÿ5ZÿR2*ÿ9&#ÿSTTÿQQQÿý***ÿ999ÿ333ÿ?'%ÿP.+ÿP/)ÿ	ÿ ÿ0ÿA%ÿ? ÿ?!ÿ-ÿ344ÿ666ÿý777ÿ;;;ÿ344ÿ‚qrÿ”{{ÿlJIÿÿÿÿ ÿK*!ÿB$ÿ'ÿ677ÿ666ÿ!!!ýLLLÿmmmÿSTTÿl^aÿ° £ÿ˜{€ÿjELÿ¬š¡ÿ2ÿT54ÿ[:7ÿJ.)ÿ$ÿ===ÿ<<<ÿ###ýPPPÿiiiÿÿ0)+ÿÓËÎÿ­”›ÿ•pxÿ‹dkÿ†_dÿzVZÿhHJÿ@++ÿ0,+ÿWWWÿBBBÿ$$$ýSRRÿ<<<ÿÁÀÀÿ•••ÿH>Aÿ{hnÿ¾­³ÿ²›¢ÿ†ckÿqU[ÿO:>ÿ)!ÿeeeÿnnnÿ888ÿ!!!ýWWWÿKKKÿwwwÿÚÚÚÿ¨©©ÿ2+-ÿŽ…‡ÿª¢¥ÿLQÿI<?ÿ3./ÿ‰ŠŠÿ•••ÿ[[[ÿIIIÿ!!!ý```ÿXXXÿWWWÿÿøøøÿîîîÿ²³³ÿpppÿqrrÿ«««ÿÌÌÌÿÊÊÊÿqqqÿXXXÿXXXÿ!!!ýiiiÿdddÿdddÿdddÿdddÿÓÓÓÿùùùÿþþþÿùùùÿìììÿ½½½ÿbbbÿdddÿdddÿdddÿ###þ111ÿ‚‚‚ÿ………ÿ‰‰‰ÿÿ‘‘‘ÿÿ‹‹‹ÿ‰‰‰ÿŠŠŠÿŒŒŒÿˆˆˆÿ„„„ÿ€€€ÿwwwÿ           ÿ   ÿ   ÿ   ÿ                   ÿ   ÿ   ÿ   ÿ            ÀÀÀÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ   ÿ        ÀÀÀÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ   ÿ        ÀÀÀÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ   ÿ        ÀÀÀÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ   ÿ            ÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿ                ÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿ        ÿÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿÀÀÀÿ           ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿÀÀÀÿ           ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿÀÀÀÿ           ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿÀÀÀÿ           ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ € ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿÀÀÀÿ           ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ € ÿ € ÿ € ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿÀÀÀÿ           ÿ€€€ÿ€€€ÿ€€€ÿ € ÿ € ÿ € ÿ € ÿ € ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿÀÀÀÿ           ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ € ÿ € ÿ € ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿÀÀÀÿ           ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ € ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿÀÀÀÿ           ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿ€€€ÿÀÀÀÿ           ÿ   ÿ   ÿ   ÿ   ÿ   ÿ   ÿ   ÿ   ÿ   ÿ   ÿ   ÿ   ÿ   ÿ        ïVVVÿ===ÿZZZÿ§§§ó                    ~        ÿ^^]ÿ   ÿ   ÿ   ÿÿ   ÿ%%%u            TTTð'((ÿ'((ÿ'((ÿ'((ÿ122ÿJJJÿÿ   ÿ‰‰‰ÿŠŠŠÿ333ÿ‚‚‚Ë            TTTó@'ÿÿ¦;ÿɇ=ÿyZ7ÿ*$ÿ  ÿ ÿ %ÿ"#%ÿ<<=ÿ”””þ555W****        YYYÿ@'ÿ­j#ÿ“^'ÿ£r>ÿÁXÿÜ­xÿœuMÿŠeAÿ|hSÿXH9ÿÿ  	ÿ  ÿÿìYYYÿ.ÿŠQÿpGÿ+#ÿ#ÿ?3$ÿ%ÿ
Re: Error: not well-formed (invalid token) at line 76
Post by steve » Sun Mar 27, 2011 2:17 pm
The text from the .AUP file has come out as garbage.
Could you post the actual .AUP file to the forum. (Use the "Upload Attachment" tab below the compose message text box)
fiveways
Post by fiveways » Sun Mar 27, 2011 8:01 pm
Okay
A day in the life remix project.aup
(16.29 KiB) Downloaded 22 times
Post by steve » Sun Mar 27, 2011 9:08 pm
Unfortunately a large part of the file from Line 75 is corrupt.
Did Audacity crash? If so, what were you doing at the time? If not, do you have any ideas of how the file may have been corrupted? Are there any other problems that you know of with your computer?
fiveways
Post by fiveways » Mon Mar 28, 2011 3:34 pm
steve wrote:Unfortunately a large part of the file from Line 75 is corrupt.
Im pretty sure i just closed it down and saved it normally. I have no idea how it could have been corrupt and nothing like this has ever happened before on my computer.
Post by steve » Mon Mar 28, 2011 6:57 pm
It would probably be a good idea to do a thorough check of your computer system. Start with a full-strength virus scan, then give the hard drive a thorough test. To test the hard drive, if you know the make of the hard drive, most hard drive manufacturers have diagnostic test programs available on their web sites, if not, then then run chkdsk.
Chkdsk on XP http://support.microsoft.com/kb/315265
Vista http://www.windows-help-central.com/win ... hkdsk.html
