need help bad recording with audacity 1.3.12 beta.
I need help. i'm using fl studio and under input/output i'm using asio4all so i won't have latency. but.. i was trying to record in audacity and when i press record it say's "error while opening sound device. please check input device settings and project sample rate. but if i select speakers or primary sound driver (on fl studio) i get latency and weird noises with audacity. i guess it won't let me use asio4all and record with audacity. i'm sure there is a way around this i hope. please help me.
Re: need help bad recording with audacity 1.3.12 beta.
do you know another audio recording program i can use with asio in fl studio?
Why not just use the recording feature that is built into FL Studio?
I'll be honest im new with fl and i just now figured out how to import nexus into it. i tried recording but when i saved it as mp3 and tried to listen to it through wmp or zune i can't even hear my song. i hear it while i record but not when i try listening to it after i saved it. i'm not sure how to correctly set up my audio. i'm a big noob. i've played piano all my life and i'm just now starting to use software.
I think you may just need to spend a bit of time looking through the FL Studio manual.
There's also lots of FL tutorials on YouTube.
