mic recording audio too low
dhdd
Re: mic recording audio too low
Post by dhdd » Mon Mar 28, 2011 8:58 pm
Thanks Steve, I'll try, but I'm not that great at troubleshooting but I'll see what I can do.
dhdd
Post by dhdd » Tue Mar 29, 2011 9:49 am
Well this is tremendously frustrating, I checked and wiggled and cleaned all connections w/ no success, also I went into realtek audio mgr-> audio devices -> recording-> line in-> properties-> enhancements, clicked disable all sound effects but there was no change. So I connected the line out of my mixer to the mic in port of computer and there I got a strong recording signal albeit w/ some background hiss. I have to get my voice recorded for my upcoming radio show, will this connection be alright Steve?
bgravato
Operating System: Linux Debian
Post by bgravato » Tue Mar 29, 2011 10:06 am
dhdd wrote:So I connected the line out of my mixer to the mic in port of computer and there I got a strong recording signal albeit w/ some background hiss. I have to get my voice recorded for my upcoming radio show, will this connection be alright Steve?
The signal coming from the mixer should be a line level signal, which is considerable stronger than a mic level signal. Mic input on the soundcard is expecting a very tiny signal (from mic) therefore it puts a lot of amplification on it. Consequently amplifying very much the noise too. Connecting a line level signal to a mic input usually results in a lot of distortion due to clipping. But if it works for you with satisfactory results then go for it while you can't find a better solution...
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
