Can only select in second intervals?
Shinami
Post by Shinami » Tue Mar 08, 2011 4:24 am
I feel a bit stupid for asking this, since it's probably something easy to fix, but I can't figure it out. Plain and simple, for some reason I can only select in one second intervals on my 1.3 Beta. It's really annoying, because just a few weeks ago I could select whatever I wanted. I might have pressed a button - the change happened when I was syncing various sound tracks and my computer was running slow. Any solutions so I don't have to go through uninstalling and reinstalling?
Re: Can only select in second intervals?
Post by kozikowski » Tue Mar 08, 2011 6:27 am
At the bottom of your work window, do you have "Snap To" selected? Deselect it. You may need to restart Audacity.
Shinami
Post by Shinami » Tue Mar 08, 2011 8:16 pm
Ah, thank you! That solved it and was really simple - I didn't even notice I had that selected. Thanks!
