hola, queria consultarte sobre un problema que estoy teniendo con el audacity(beta).. cuando lo abro no se maximiza, aparece en la barra de inicio, pero no puedo ejecutarlo, lo he podido usar un par de vez, y luego me sucedió esto. Intenté desinstalarlo y volverlo a instalar, pero parece obtengo lo mismo. Quisiera seguir usando el 1.3, ya que el 1.2 es incomodo y no obtengo los mismo resultados. Me he fijado en otros lugares, y a varios le pasó lo mismo, por favor, aguardo tu respuesta, gracias!
Windows 7 - 2gbram
Hi, I wanted to consult you about a problem I'm having with the audacity (beta) .. when I open not maximized, appears in the task bar, but I can not run, I could use a couple of time and then this happened to me. I tried uninstalling and reinstalling, but it seems I get the same thing. I would like to continue using the 1.3, since 1.2 is uncomfortable and I get the same results. I looked at other places, and many did the same, please await your reply, thanks!
AUDACITY 1.7 se bloquea en la barra de inicio :(
nicobolso91
- Quality Assurance
Re: AUDACITY 1.7 se bloquea en la barra de inicio :(
What do you mean by "1.7"? if you mean "1.3.7", the current Beta is 1.3.12 and includes many bug fixes including a fix for the issue you raise. You can often fix that issue in older Betas by right-clicking over the Audacity Taskbar icon > Maximise, or by resetting the audacity.cfg settings file.nicobolso91 wrote:Windows 7 - 2gbram
But it would be far better if you upgraded to 1.3.12:
http://audacity.googlecode.com/files/au ... 1.3.12.exe
nicobolso91
thanks, now works, no doubt think it was the version that runs 31.3.12, if I have a problem i will do What you said about the register, thank u !
nicolas, uruguay
nicolas, uruguay
