I am having difficulties with the equalizer on Audacity 1.3.12. I was messing around with it and now I can't get it to go back to its original setting. Additionally I accidentally deleted the "acoustic" curve profile (I didn't realize that was what "delete" was going to do!! oops) and now I can't get it back. I even tried uninstalling and reinstalling audacity, but the equalization is still messed up. Can you give me any help on this?
Thanks in advance!!
Julie
oops! problems with equalizer
Re: oops! problems with equalizer
The Equalizer can be set to a neutral "flat Eq" setting by clicking on the "Flatten" button.
To restore the original pre-set curves list:
- Close Audacity
- Search your computer for the file "EQCurves.xml"
You will need to enable searching for hidden files because by default it is in a hidden folder. - Delete the file EQCurves.xml
- Restart Audacity
