Recently, ive recorded a 1 hour mix on the Audacity in my friend's Macbook and after it was done, ive saved it as an .aup file into my portable hardisk. As such, im unable to load it from my portable harddisk to my Audacity on my laptop. From the Audacity, ive click open and selected the .aup file, but then a window pop up and stating "COULD NOT OPEN FILE". Afterwhich, ive tried to open the file in the folder (data) and a window pop up stating "DATA REFERS TO A LOCATION THAT IS UNAVAILABLE. IT COULD BE ON A HARD DRIVE ON THIS COMPUTER, OR ON A NETWORK. CHECK TO MAKE SURE THE DISK IS PROPERLY INSERTED, OR THAT YOU ARE CONNECTED TO THE INTERNET, OR YOUR NETWORK AND THEN TRY AGAIN. IF IT STILL CANNOT BE LOCATED, THE INFORMATION MIGHT BEEN MOVED TO OTHER LOCATION"
Need your help urgently as im meeting a tight deadline for an important project using Audacity. Thank You.
