Time Shift = too far [Solved]
MysticalChicken
Post by MysticalChicken » Wed Feb 23, 2011 6:33 am
I have two tracks I want to mix, and I need to move one of the tracks a tiny bit so it's in sync. Problem is, the Time Shift tool moves it too far. I only need it moved about 1/10th to 1/5th of a second (not sure of the exact timing, but the tracks are definitely not in sync when I listen to them), and Time Shift seems to move it about half a second and I can't get it to fine-tune to where I want it. How do I move audio in like 1/5th of a second increments?
edit: Okay, I zoomed in on the tracks and that seems to work for fine-tuning the timing.
