Need help!!!
Berlovan
Need help!!!
Post by Berlovan » Sun Feb 20, 2011 11:03 pm
I really need some help now. I recorded something and i want to edit it. But how do i make to listen it slowr ? NOT TO MAKE IT GO SLOWER .. Only to listen to it slower ?
justinburnett
Re: Need help!!!
Post by justinburnett » Mon Feb 21, 2011 1:31 am
Hi
If you've using version 1.3.12, in the top right hand corner of the toolbar you will see another green triangle with a sliding bar next to it. This controld playback speed. Just slide it one way or the other to choose the speed, then press that green triangle. The pitch will be lower, but the song will be playing slower.
Take care
-J-
