Audacity will no longer open....
TheLegendaryJaredLee
Re: Audacity will no longer open....
Thank you so much, the code worked, I guess that was the problem. I am so happy now, you really don't understand how grateful I truly am.
Well, I have the same problem again..... Only this time nothing is working, any answers?
- Quality Assurance
Please check your exact Audacity version at Help > About Audacity. If it's less than 1.3.13 (for example, 1.3.12) get the 1.3.13 download:TheLegendaryJaredLee wrote:Well, I have the same problem again..... Only this time nothing is working, any answers?
http://audacity.googlecode.com/files/au ... 1.3.13.exe
Force quit the old version of Audacity on the "Processes" tab of Task Manager, install 1.3.13 then before launching 1.3.13, repeat the edit of audacity.cfg as before:
Code: Select all
NewPrefsInitialized=1
[VST]
Enable=0
GUI=0
Rescan=0
