Random skipping when recording
funkywobin
Post by funkywobin » Sat Feb 12, 2011 1:56 pm
Hi,
I am using audacity to record my DJ sets, but when i listen back to what i've recorded, i hear a sound like the record is skipping when i am dj'ing the records aren't skipping so i know its not the tracks i own, if any one could help with this, i will be really grateful
Thanks
Re: Random skipping when recording
Post by kozikowski » Sat Feb 12, 2011 2:09 pm
Audacity will not work into a full or badly fragmented hard drive. You need to keep at least 20% free space to do live audio (or video) production.
Defrag
-- Right Click Start > Explore > Right Click Local Drive C: > Properties (Used, Remaining)
-- Tools > Error Checking & Defragmentation
Post by steve » Sat Feb 12, 2011 3:34 pm
funkywobin
Post by funkywobin » Sat Feb 12, 2011 7:21 pm
Cheers guys,
Koz i tried the defrag but no joy but i'll give it a go with the link i've been set didn't realise there was a section regarding skipping.
will let you know if this works!!
cheers for the help too!
Post by kozikowski » Sat Feb 12, 2011 7:34 pm
Virus Protection, Email, Photoshop? There can't be any competition for the computer time, either.
You could have a ratty digital connection and that will create problems. Replug everything once or twice. Is it actually clear, missing musical notes, or is there noise, too.
funkywobin
Post by funkywobin » Mon Feb 14, 2011 6:27 pm
Hi,
thanks for all the info koz, but i still cant get the random skipping, i've turned the internet off turned the antivirus software, unplugged everything more than once, i used to be able to record ok until, i upgraded to windows7, do you think that could of caused this?
Post by steve » Mon Feb 14, 2011 8:35 pm
If you open Audacity and go to "Edit menu > Preferences > Devices" there are 2 options for "Host". Try the other option.
funkywobin
Post by funkywobin » Tue Feb 15, 2011 6:10 pm
Thanks for the info, but again i tried this and still no joy, i'm wondering if its my soundcard, from when i upgraded my operating system, i had to reinstall the drivers for the soundcard!!!
Post by steve » Tue Feb 15, 2011 6:23 pm
What do you have set in:
"Edit menu > Preferences > Quality"
funkywobin
Post by funkywobin » Tue Feb 15, 2011 7:55 pm
Sample rate is 44100hz
Sample format is 32-bit float
real time
sample rate is fast sinc interpolation
difther none
conversion
sample rate is high-quality sinc interpolation
dither shaped
