Recording vinyl
Recording vinyl
I have an 20 year old pioneer system works perfectly well. Trying to record vinyl but there is lots of noise, like feedback. I had to recoonect the turntable cables having cut them a few years ago. Could this be the problem? Any help.
Re: Recording vinyl
If you are feeding the signal from the turntable into the computer's mic socket that could explain a distorted sound, (should use computer's "line-in" socket) ... http://manual.audacityteam.org/man/How_ ... _equipment
Re: Recording vinyl
Thanks I will try that, but I think I'm going through the line in socket.
Re: Recording vinyl
The main "Recording vinyl" on Audacity FAQ is here ... http://manual.audacityteam.org/man/Tuto ... iscs_to_CD
