I have hundreds of wav files that I'd like to reduced the volume of.
I know this far
-Drag & Drop files into Audacity
-Click the area on the left of the file under the x.
-Files>Select All
Now what? Surley I don't have to move that "gain" slider for each file?
Reducing Volume - Mass Files
Re: Reducing Volume - Mass Files
See here: http://manual.audacityteam.org/man/Edit_Chains
and here: http://manual.audacityteam.org/man/Apply_Chain
Right, Thanks. (needed beta).
1 last thing. What is the the command I want for reducing vol, like the "gain" slider?
Use the "Amplify" effect and set the amplification amount to a negative amount to reduce the volume.
Great. Thank You. Done.
