Background color
Background color
Hi all. I'm new to the Audacity code base. I was wondering if anyone knew how I could change the background color of the scroller area? I was able to change the main panel color in Project.cpp by doing a "pPage->SetBackgroundColour(theTheme.Colour( newColor ));" but the scroller background color remains gray. Thank you in advance!
- Quality Assurance
Re: Background color
Unfortunately I don't know much about Theming and colours. From the comment above this line:
that code is commented out because it can lead to the scroller background being painted as clrDark. So the intention of enabling that line is *not* to change the scroller background. Is the whole of the scroller background still the original light grey?
James knows most about these matters, so I would suggest you subscribe to audacity-devel mailing list and ask there for some pointers.
Code: Select all
//pPage->SetBackgroundColour( theTheme.Colour( clrDark ));
Hi Gale,
Thanks for your reply. Yes, the scroller background area stays in the default light gray
- Quality Assurance
If you uncomment that line with no other changes it paints the entire scroller background black without changing the background colour.Gale Andrews wrote:Unfortunately I don't know much about Theming and colours. From the comment above this line:that code is commented out because it can lead to the scroller background being painted as clrDark.Code: Select all
Hi Gale,
When I uncomment that clrDark line, I see the areas surrounding the scroller background area to be dark, but the scroller background stays light gray. Have you changed something else?
Thanks!!
Thanks!!
- Quality Assurance
No, all I did was remove the "//" from in front of that line, so:francine wrote:Hi Gale,
Code: Select all
