I'm having probs with recording through my Line-in Realtek card.
When I start a new tape, I find the recording levels seem to be set at a strange level, and the level is not consistent. I'm recording from tape, and as usual there is a lead-in (approx 14 secs) of silence (obviously there is tape noise etc)
The most common result I'm seeing is that the record level starts at the base of the graph, and then rises steadily (although the playback sound does not). Usually it settles down after a few seconds, but not centered on the 0 level.
I have stopped and started frequently, and eventually, I seem to get a "correct" level, and from then on it is fine till I start a new recording
The image below shows an example of the results I'm seeing.
