Remove keystroke audio
How do you remove the caused by touching you keyboard keys? I realize you can remove noises but i am not experienced enough to know what decibel needs to be removed. The stroke is as loud as it goes the meter will read.
Re: Remove keystroke audio
Did you record a performance on the built-in laptop microphone while you were typing?
There's no good way to get rid of that noise other than selecting each key noise one at a time and applying Amplify or other filter. I know of no way to start a filter at the beginning of the show and have it automatically fix them all.
If you look at the blue waves on the timeline, are the key noises much larger than the show -- can you find each one easily? Steve created a new tool to help suppress pops like that.
http://forum.audacityteam.org/viewtopic ... 39&t=50671
