I was playing at a consistent volume all the way through, but for some reason, the recording volume is automatically going down, I assume to prevent the levels from maxing out. But I don't mind the levels maxing out; in fact I want them to, but I can't figure out how to stop the program from doing this.
This happens in both Audacity 1.2.x and 1.3.x. My setup is that I am playing a guitar through an amp, and the amp's output is going straight into to my laptop's microphone jack.
Here is a WAV file of the recording pictured above. I played a G chord at the same volume ten times in a row; you can clearly hear the volume levels lowering themselves:
http://www.mediafire.com/?fxx37q9kbt2i7yf
thanks for reading, any help would be hugely appreciated!
EDIT: I have tried skipping the amp and plugging the guitar straight into the mic jack; the result is the same.
