So there is, and I've got an idea what the problem might be.bernofsk wrote:P.S. Aha, so it IS a Safari problem. There's a whole discussion forum devoted to this specific problem
Do you have a "Tag Editor" program for editing the id3 tags (metadata) in MP3 files?
(You can do it in Audacity, but Audacity needs to decode and re-encode the MP3 file and it would be better not to do that).
Perhaps you can edit the tags in iTunes?
Delete the "Comment" tag, then re-upload the file and see if the file then works. (there's some non-ascii characters in the comment tag that may be causing the problem)
