Tool for taking out gaps in sound?
Zero Emissions
Post by Zero Emissions » Mon Jan 03, 2011 4:23 pm
Hello there,
Is there a tool for automatically removing any gaps in sound in my recordings? At the moment I have to trawl through hours of recordings to manually remove any gaps (these are fairly frequent as Im recording Internet radio).
Thanks,
The Zero Emissions Edition
Re: Tool for taking out gaps in sound?
Post by steve » Mon Jan 03, 2011 6:07 pm
Effect menu > Truncate Silence.
You cannot completely remove a silence with this tool, but you can truncate it down to 1 millisecond (0.001 second)
If the silences are long, you may need to run the tool several times.
The maximum "Silence Compression" is 20:1
The minimum "Min Silence Duration" is 1 millisecond.
Zero Emissions
Post by Zero Emissions » Mon Jan 03, 2011 7:50 pm
Nice on Steve, you've saved me a lot of time.
