Line 6 Gearbox problems
TomVAtkinson
I am having a problem, started today, where my Line 6 Gearbox, and Pod Farm 2 software is working fine, but now Audacity is not picking up anything I play when I try to record! I've changed nothing. Any ideas or what to look for? Thanks!
Re: Line 6 Gearbox problems
Ensure that the hardware is connected before you open Audacity.
If you are getting no signal in Audacity, check that the correct recording device is selected in "Edit menu > Preferences > Devices"
