This must be obvious to someone, but it is a conundrum for me. I recorded from a tape, split the recording into tracks with "Add Label at selection" using the track names, then attempted to export the files as FLAC files. When I hit "Export Multiple..." I get a "Edit Metadata" dialog box which repeats back to me each track and it's name every tilme I hit "Save. After the last track it takes me back to the "Edit Metadata" dialog box. What do I do then? If I hit "Export" again it just takes me back to the "Edit Metadata" box again where I do everything again, around and around. How can I export these files?
Thanks, Warren
Export Multiple>Edit Metadata>then what ????
Re: Export Multiple>Edit Metadata>then what ????
What version of Audacity do you have?
I am confused about "Save", this serves different purpose.
In my Audacity 1.3.5. I leave the "Edit Metadata" window by pressing "OK".
After last track, Audacity does the export, says "Succesfully exported 4 files" end leaves the "Export multiple" dialog.
You say you get back to ... what dialog? - You probably mean the "Export multiple" dialog if there is an Export button.
This is strange. Did you look if there are some files exported?
- Quality Assurance
If you don't want metadata in the files, use 1.3.5 and turn the appearance of the editor off in Import / Export Preferences. The behaviour is odd, but try 1.3.5 if you are not already,
