I just recently downloaded Audacity.
I've been trying to get a song onto Audacity to edit it for a school project. I finally managed to get more than less than a second of the file onto the program, but when I hit the play button all it gave me was white noise, the static-y kind that you get from a bad TV channel. It is an mp3 file, obtained from a website that pulled the file from a Youtube video. I only want to cut out part of the song, so the fact that this is happening is adding to my overall stress, and quick responses would be very much appreciated! I desperately need some help!
Importing Problems-White Noise
Re: Importing Problems-White Noise
Check that you are using the latest version of Audacity (1.3.12) and have FFmpeg installed.
http://audacityteam.org/download/beta_windows
http://manual.audacityteam.org/index.ph ... tallffmpeg
I am definitely using the latest version of Audacity. I'm not sure if I got FFmpeg installed or not. I went through the installer but when I started up Audacity again and imported the file, it did the same thing to the file. How do I check if FFmpeg got installed?
See here for full instructions: http://manual.audacityteam.org/index.ph ... tallffmpeg
