Cut Feature Not Working
jracine690
Post by jracine690 » Sun Dec 12, 2010 12:27 am
Not sure if anyone can help. I have been testing Audacity and it is not letting me cut a section I want to delete. I was only testing the feature on an 8 second recording, but does not work. Any advice??
Thanks
John
Re: Cut Feature Not Working
Post by kozikowski » Sun Dec 12, 2010 3:34 am
Just as a test, drag-select some small portion of the show and press the delete key. The production keys will not work if you capture something live and press pause at the end instead of stop.
