Garbled Sound
rsgood
Garbled Sound
Post by rsgood » Wed Dec 08, 2010 2:14 am
After I purchased a new computer with Windows 7 I downloaded the Beta version of Audacity. It works fine when I record tracks from an external source using the external line input. But when I use my Numark TTUSB turntable with a USB connection the sound is so garbled that I won't be able to record it. What I am I doing wrong or is there a configuration fix for this problem?
rsgood
rsgood
Re: Garbled Sound
Post by rsgood » Sat Dec 11, 2010 2:17 am
Problem solved. Numark has a new driver on their website for Windows 7 called 'EZ Converter'. It is more complicated and requires that itunes be installed on my computer. I did all that and now everything works just fine.
