Copy and pasting MP3 files will result in pitch change
billw58
Re: Copy and pasting MP3 files will result in pitch change
Post by billw58 » Mon Dec 06, 2010 10:29 pm
Gale Andrews wrote:The only other 1.3 version I have to hand (1.3.3) does not have the problem.
Problem exists in 1.3.5d Mac. In 1.3.3 Mac, pasting into a track with a different sample rate creates a clip. It appears that from 1.3.5d onwards the clip is not created.
-- Bill
Post by Gale Andrews » Mon Dec 06, 2010 11:15 pm
billw58 wrote:Problem exists in 1.3.5d Mac. In 1.3.3 Mac, pasting into a track with a different sample rate creates a clip. It appears that from 1.3.5d onwards the clip is not created.
Thanks, Bill. I've established it broke in 1.3.4. In 1.3.3, seems that any paste creates a clip e.g. between tracks at same rate. I never liked that.
Post by steve » Mon Dec 06, 2010 11:41 pm
Gale Andrews wrote: cut or copy and paste from the 44100 into the 48000 Hz.
Ah ha! That's the bit I was missing.
I can reproduce the bug on Linux and XP.
I often paste audio clips of different sample rates, but I always deal with them as discrete clips.
The bug only appears if audio is pasted into existing audio that has a different sample rate.
At least this points to an easy workaround for tablo:
Before pasting the copied audio, click at the place where you want to paste it, then press "Ctrl+I"
This will "split" the audio in the track that you are pasting into.
You can then use Ctrl+V (or select "Paste" from the Edit menu) to paste the audio.
The audio will now be pasted as a discrete audio clip and will play at the correct speed.
Post by Gale Andrews » Wed Jan 26, 2011 12:03 am
This problem will be fixed in the next 1.3.13 Beta. Thanks for the report.
