Hey all, just started using Audacity. I have Windows 7 64 bit version with a Soundblaster Audigy 2 ZS with latest drivers.
I'm trying to record a tape through the line-in port and when I play the tape I can hear the audio. However in Audacity when I choose Start Monitoring the monitor graph above the button shows no audio at all, and when I record the file is blank. I have set the recording level to about 75% in all mixer menus. My recording device is "Analog Mix (LINE IN etc.)". What's odd is last night I was able to see the audio levels and record it, though the sound was very distorted when I played it back. Anyone know a solution to this?
Thanks!
No sound on monitor, can't record
Re: No sound on monitor, can't record
Analog Mix does not select your Line-In connection. Deselect that and find the actual Line-In. Make sure Audacity has the same thing selected in its preferences. Restart Audacity if you have to change anything.
That's problem 2. Are you on a laptop? Chances are good you have no Stereo Line-In connection. Does the connection say "Mic-In?" That's for a microphone, it's mono, and it overloads very easily.the sound was very distorted
