Editing problem
Don S
Editing problem
Post by Don S » Wed Nov 10, 2010 9:12 pm
On my recorded track, I'm using the selection tool and when I place the cursor in one place and in order to select a small section, the editing jumps ahead one full second, rather than smoothly a fraction of a space. It only makes these one second jumps. I checked manual and can't find which item to fix problem. It hasn't done this in the past.
Re: Editing problem
Post by steve » Wed Nov 10, 2010 9:14 pm
Toward the bottom of the Audacity window there's a tick box "Snap To"
Switch it off.
Don S
Re: Editing problem
Post by Don S » Wed Nov 10, 2010 10:50 pm
Steve: Thanks. You're right. Just before I read your reply, I had discovered the problem, fixed it, and then read yours.
